Odd WB02 readings. Progressivly lean
Old Aug 18, 2024 | 02:00 PM
Forcefed86's Avatar
Default Odd WB02 readings. Progressivly lean
I have an AEM WB02 gauge setup in the same way I've run them on all my cars. It appears to be accurate at idle, part to 3/4 throttle. When I go wide open throttle it progressively leans out. I assumed this was in the tune initially so I added fuel, nothing happens. I can add fuel until the engine stumbles, so I know it is getting too rich to run correctly. Fuel pressure an all are solid.
Then I assumed it was the sensor. So I changed the sensor out with new. No changes. Anyone have this issue before? I don't appear to have any exhaust leaks. sensor is in the collector with a full exhaust.
