Holley Terminator: Wideband O2 failure rate
Been limping along, trying to get a nice little 383 GM crate motor to run smoothly with Holley Terminator.
Had a bad MAP sensor ( Holley).
Replaced a bad wideband O2 sensor ( Holley)
now getting extreme driveability problems, runs ultra pig rich, too stinky to drive. Possible that I have destroyed a second HOLLEY wideband ?
They are expensive these days, and really should NOT be a "wear part". Is there a recommended aftermarket WB O2 that can work with the Terminator ?
The AEM Wideband on my Tahoe is doing just fine since 2016
Nice price.
Thanks for the tip.
Thanks for the tip.
Wideband O2 sensor installed on 3" collector rusty Walker Y-Pipe. Noticed some open cracks at the Y, probably bringing in a buncha AIR.
Have a new Y on order. That might help, IF I can get the tune re-loaded.
The Holley touchscreen is acting up, doesnt want to read from my SD card saved files.
Probably would be cool to write a straight up SEA-Level OPEN LOOP SD tune to load in emergency.
Have installed a new Walker Y-Pipe, old one had a crack big enough to stuff dollar bills in, 6 inches UPstream of Oxygen sensor Bung. Been chasing my tail trying to tune for years.
Hit the O2 sensor with a mapp gas flame to ' cook the carbon out' put in some clean used ngkTR5, Terminator is running smooth now.
