LS3/4L80E Issues - P0751
The truck drives well, shifts well, but will go into Limp Mode and get stuck in second gear pretty regularly. I replaced fluid, filter, and shift solenoid A just to be sure, but as these are new units, it all looked good as expected. Behavior remained. The Supermatic software describes P0751 as follows:
P0751 - High Ratio Error
No DTC 21,22,24,38,72,74 Sets when not in P,R,N, RPM is greater than 300rpm, TPS is greater than 25%, VSS is greater than 7mph, Transmission Ratio matches 1st or 2nd gear when 3rd or 4th gear is commanded, for 6 seconds.
On a recent test drive while datalogging, I noticed both times I replicated it was up a steady hill while holding second gear. I thought nothing of it, as I would expect the trans to hold that gear given my throttle position. It seems it just got mad it was in that gear for too long?
At this point I really feel this is a tuning/software issue and not a mechanical issue. I attached the calibration and datalog in a .zip
Any and all help and advice is appreciated,
Thanks
