Ob2 scanner not able to read pcm
Old Aug 31, 2024 | 01:53 PM
chrisv45's Avatar
Default Ob2 scanner not able to read pcm
So currently I'm working on a 97 Chevy obs with an lq9 swapped. I got everything working on it besides My scan tool will not read the pcm And won't Stay running For more than a couple seconds before it bogs down and dies. I have all grounds 12v constant and 12v switched verified to the pcm. Data wire is there as well. Vats turned off in the tune. Curious what else should I check? Could it be possible the pcm is bad because i've been looking into this thing for a couple of weeks now and I don't know what else to do. Someone please help haha
Old Sep 1, 2024 | 09:06 AM
pcguy's Avatar
Possibly two different issues involved. One is the pinout on the plug. Specifically check the power on 4 and 16; without that and without the key on, the scanner won't connect. The other issue might be found in a code when the scanner is functioning...
Best, Nick
Old Sep 1, 2024 | 02:20 PM
chrisv45's Avatar
The scanner will turn on, just not communicate. I have ground and power, just no continuity when chasing the data wire.
