diagnostic scanner
Where is the OBD2 data port connector in your Camaro?
My Bluetooth hardware is either a Chinese Konnwei device, Nexas Nexlink or an OBDLink MX. I've also got a VXDiag "Nano" but I don't recommend it. These types of hardware devices can't do everything that the HP Tuners MPVI3 can do but I'm a cheap tight wad. Fortunately, I don't need HP Tuners very often though a coworker may about be ready to sell his MPIV3 for cheap.
Rick
How are you controlling the engine? I would imagine most folks are running a 0411/P59 ECU and wire up an OBD2 port, then you can plug in any scanner as if the vehicle was a late 90s/early 2000s.
I don't the VIN has much to do with reading stuff like codes and live data. You can program a VIN on the ECU with HP Tuners, et. al.
I'm not sure if any of this applies if you are using an aftermarket ECU like Holley though...
Pre-96 cars are going to use the OBD1 style connector.
You are going to need an OBD2 port/scanner to talk to your LS3 unless you are using an OBD1 computer.
With an "off the shelf" scanner, if you know what year/vehicle the PCM came out of, you can do it that way. If you are using HPTuners, it doesn't matter if you know or not.
I'm a little lost with what exactly you have going on here...
