LS3 on Build - Idle Issues
You say "standard LS3 MAF" but there are variations. Please give us the part number and ideally a picture. If it came integrated with an air tube, you need to use that tube (almost certainly smaller than 102mm). If its a blade MAF, then it will fit many air tube setups, but definitely has to be tuned. (I recently learned that blade MAFs have a different connector/pinout than older style MAFs.)
I also think you will have to do all the airflow tuning.
