Pending Codes P0101 P0341 Issues
locally dyno tuned then street tuned as I had high negative LTFT and hated the trans shifting.
Eng light doesn’t come on but I will get a pending 101 MAF code and it’ll pop thru the intake under throttle. Random 341 code as well even with new cam sensor. MAF was new with the build and 1k miles on the build.
Could it be an intake or header leak causing this? Tune related? 02’s?
As soon as I clear the pending code it runs normal. Usually after WOT it runs bad. Everything with the engine is new but stock coils.
I was dumping fuel at one point with 2 open injectors. Wonder if the speed engineering CAT is now shot.
truck runs fine until the 101 code starts pending. As soon as I clear it then it runs normal again. Maybe the new MAF is bad or a bad wire. I was thinking the cat is clogged due to the 2 injectors dumping fuel that I fixed with a new ECM due to an arc while checking spark fried the ECM in those two spots. I had them copy my ECM to a new one. Starting to think it’s in the tune. All sensors aside from the crank are new.
cam is 216/228 .600 with btr dual valve springs. Engine only has 1k miles.
Bad grounds can also cause weird codes - if the MAF and cam sensors are grounded together that would be a suspicious coincidence.
Engine runs good aside from idle from 650-750. After I hit 4k when it goes straight to MAF and no MaP (SD) is when it trips a code. If I stay under 3k it appears to be fine for the most part. Once it throws the code it backfires horribly and won’t accelerate.
Im getting ready to go turbo and SD tuned but would like to get this worked out prior to.
Forget what I said about a vacuum leak - if that was the issue then it would be lean at idle and get better at higher RPM / more load.
I’m also going to an LS7 MAF and 4” housing. The MAF housing now is 1/8 too small for the filter connection. I’ll get it retuned and that will hopefully fix the MAF issue. Just not sure on the CAM sensor.
