Question about adding options to BCM using Tech2 and software
Old Apr 6, 2025 | 01:44 PM
TRex's Avatar
Does anyone know anyone who does mail in service?
Old Apr 6, 2025 | 04:03 PM
Bbknucks's Avatar
Check with white automotive and media services. They can do all sorts of customization. Like extending remote start time , removing drl and hyperflash turn signals.
https://www.whiteautoandmedia.com/pr...m-programming/
Old May 3, 2025 | 01:44 PM
tonyorlo's Avatar
TRex, any chance you found a solution or reached out to whites?
Not trying to steal the thread, I am converting a TB to a TBSS (both titled in my name) and I have a few features I want to bring over and a few I don’t care to leave. It would be great if the mirrors and heated seats plugged right in and worked, but I doubt it. Both can easily be wired up to work “standalone”, but the steering wheel controls and display center in the cluster are doubtful to plug and play.
Not searching for answers just looking for a direction to start.
Edit:
I have access to the latest snap on scan tool at work, our fleet mechanics have it. Is it possible that it can make changes? I know they can set limiters with it on the dodges we have.
Old May 3, 2025 | 06:29 PM
TRex's Avatar
Edit:
For my situation, I received information that the programming I needed was in the door switch modules, not the memory module or cooling module or bcu. Not sure of the feature you are looking for in the mirrors, but my guess is if you move the door modules, seat heat control modules over it will work. I got the best answer from BT Dieselworks, you might contact them and ask which module controls what.
Old Sep 4, 2025 | 05:59 AM
TrybalRage's Avatar
While I can't advise on whether or not it's possible to do what you want, I ran into an issue with programming a new driver's window control module on my 2010 Suburban. I have a clone tech2 that I've been able to program through in the past, but when I tried to do this in Jan 2025 it no longer would work.
I ended up buying an 'OBDX Pro GT' dongle for under $150 and with that I was able to buy the subscription through ACDelco TDS to program the module. It was one of the few I found that had the required J2534 pass-through capabilities required.
Old Sep 5, 2025 | 04:39 PM
TRex's Avatar
that is great information to have on the obdx pro GT dongle! But a little busy to make a follow-up post but is it turns out you are not far from the solution. Turns out that the driver's door window switch module also controls the seat heaters , memory and air conditioning. Luckily they are not programmed specifically to the BCU. I ordered a set from a truck that had air condition seats and everything works perfectly now.
