High Idle Log EFILive
in the log I'm cruising at about 40mph @ 1600 or so rpm with my foot off the throttle. As approach a stop, i shift into neutral to be able to slow down, (at about frame 25) and the rpms spike to about 2600, all with my foot off the throttle. As the car comes to rest, the idle slowly settles down to about 900 (setting is at 650).
This intermittent problem is continuing to vex me, and maybe someone who is a more expert tuner can see something in the log I don't see.
Also, I suspect that a vacuum leak could cause similar behavior, even if the tune was dialed in perfectly.
Throttle cracker varied between 0 and 0.32. Throttle follower was zero across the log.
@RevGTO, I can't recall, did you ever replace your EVAP purge solenoid? Going back to our posts in the other thread, this was the answer to my (similar) problem for many years until it recently came back, but in a slightly different and more minor way (and I now think that the reemergence was likely a new/different issue related to the battery/battery cables). If the purge solenoid was occasionally opening more than commanded (or hanging open until engine restart), you would never expose this with any sort of smoke test or other vacuum leak check, as it wouldn't be a fixed leak that could be detected with the engine off. And that's what seemed to be the case for my (original) issue as well - all signs pointed to a vacuum leak, other than the fact that the issue could be cleared with a restart of the engine and no external leak source could ever be found.
Even if you look at EVAP duty cycle, all that tells you is what the PCM has commanded; there is no feedback loop to let you know how far open the solenoid actually is. So if it's sometimes hanging open more than it should be (for given conditions and PCM commands), the result will be excess air fed into the engine that is outside the control of the IAC motor and won't ever be detectable with a smoke machine.
@RevGTO, I can't recall, did you ever replace your EVAP purge solenoid? If it's sometimes hanging open more than it should be (for given conditions and PCM commands), the result will be excess air fed into the engine that is outside the control of the IAC motor and won't ever be detectable with a smoke machine.
In fact, the brake booster in my wife's car (2012 Malibu) has a very minor leak currently, and will lose power assist about 5 minutes after engine shutdown (our other same-gen Malibu will hold power assist for days), but it's not enough of a leak to cause any driveability issues. IMO, if the booster holds vacuum for more than 5 minutes after engine shutdown, any leak there wouldn't be big enough to cause RevGTO's idle hang issues, and if it holds vacuum for hours or days after shutdown then it's definitely not the cause. On the other hand, if vacuum dissipates immediately upon shutdown then it's certainly a possibility or at least a contributing factor.
