Best OS for application
Is there any advantage of moving to an 02' 12212156 OS from an 02 camaro/firebird? Better resolution or additional tables that would be helpful?
If so, is it more wise to segment swap an 02' OS OR to use a factory 02 truck OS with the 80e segment already?
This will be going into an 02' camaro with a gen3 LS, DBC, 4L80e, and will be using a speed density tune (likely an enhanced 1bar mod from Hptuners)
ALSO, will I be able to update the VIN number in my 99' pcm to match the 02' body it is currently in without updating the OS?
