Ideal EQ ratio for open loop base with e85?
Old Aug 11, 2025 | 11:41 AM
30th t/a's Avatar
Default Ideal EQ ratio for open loop base with e85?
I'm working on getting my car to have a better cold start and wanted to ask you guys what have you found to be a ideal EQ ratio for open loop with e85?
I've done alot of searching but haven't found much on this question strictly talking open loop base and e85.
This is on a built 10:5.1 CR 346, 232/240 115lsa blower cam, Procharged
thanks for any help.
Old Aug 11, 2025 | 01:34 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
There was a pretty good discussion about that on the HPT forums a year or two ago when someone was having cold start cranking problems on a flex tune. I don't remember the specifics, but cranking fuel with E85 had to be what I thought sounded insanely rich to get the engine to start when really cold. Once running, stoichiometric is fine, although cams with a bit of overlap tend to not read properly on the o2 sensors at idle.
Old Aug 11, 2025 | 05:20 PM
30th t/a's Avatar
My AEM wideband read 15-20% lean at idle although the STFT are reading dead on. So I just use them for idle tuning.
