USB to Serial Adaptor - LS1 Edit
Old Aug 28, 2004 | 04:10 PM
mikey's Avatar
LS1TECH Sponsor
Default USB to Serial Adaptor - LS1 Edit
Hey guys, I am about to purchase a new laptop PC. It does not have a serial port. Which USB to serial adaptor are you all using with LS1 Edit that works?
Mike
Old Aug 28, 2004 | 04:13 PM
horist's Avatar
ewww... I'd stay away from LS1 Edit and USB to Serial if you can help it... IE find a cheapie laptop ... I'm just really leary about USB to Serial after I lost communication during a write and had to have a dealership reflash it... (HumpinSS killed 2 or 3 PCMs to the point where not even the dealership could reflash... dnno if he was using a USB to Serial though)
Your best bet would be to buy a PCMCIA serial card (they can get pricey though but alot better than a USB to serial)
Old Aug 28, 2004 | 07:32 PM
red ws6 99's Avatar
I have yet to find anyone that has an issue with keyspan usb to serial adapter. Run them in compatible transfer mode and they are as fast and reliable as a serial port. I run a four port usb to serial adapter and log two different devices at the same time. No issues with ls1-edit, autotap or efilive, and some other programs. You buy a cheap belkin or even the autotap made ones good luck.
Gary
Old Aug 28, 2004 | 09:39 PM
mikey's Avatar
LS1TECH Sponsor
Gary
Where can you find a Keyspan Unit?
Old Aug 29, 2004 | 06:34 AM
Mark98SS's Avatar
Comp USA has the Keyspan in their online cataloug I went to a CompUSA store & bought an I-Concepts (Linex) unit, works great, about $30.
Old Aug 29, 2004 | 11:02 AM
red ws6 99's Avatar
You can get them online at www.insight.com, www.cdw.com, www.keyspan.com, etc. Some Comp USA have them. Were I live you can't get any computer stuff, so I just order them online.
Gary
Old Aug 29, 2004 | 12:36 PM
TILEMAN's Avatar
I have used a Belkin and a Radio Shack usb to serial, no problems
Old Aug 29, 2004 | 01:53 PM
-=Merlin=-'s Avatar
Would the same still apply for HPTuners?
Old Aug 29, 2004 | 02:47 PM
red ws6 99's Avatar
Should apply since the programs are just accessing the serial port. The keyspan have more consistant drivers than some of the others.
Gary
Old Aug 29, 2004 | 03:08 PM
SmaknaSS's Avatar
keyspan or Belkin F5U103 has worked with EFI live,LS1 edit,I use them at work and has also worked interfacing Many manufactures of Varible speed drives.
Old Aug 29, 2004 | 03:37 PM
MyLS1Hauls's Avatar
I've got a Radio Shack one and the only problem is that the COM port switches once and a while. You just have to make sure you know what it is because Edit isnt smart enough to automatically find it. Autotap does without a problem.
Old Aug 29, 2004 | 05:05 PM
dlandsvZ28's Avatar
If you do decide to buy a RS-232 Serial PCMCIA Card adapter (lack of a serial port), get it at Quatch (about a $120). Because of different technology, the read/write speed compared to serial is substantial.
Quatech sells the exact model # and brand as what is recommended by some but a from a different reseller and about $50 less. And they have excellent service. Got mine in about 3 days with email tracking.
http://www.quatech.com/catalog/rs232_pcmcia.php
Quatech Inc.
5675 Hudson Industrial Parkway
Hudson, Ohio 44236
Direct Dial: (330)655-9082
Main Phone Number: (800)553-1170, ext. 9082
Fax Number: (330)655-9070
Old Aug 29, 2004 | 05:17 PM
parish8's Avatar
single digit dreamer
i have a compaq laptop and i couldnt get any usb-serial to work with my edit and i fried one pcm completely. i tried a cheapy, a keyspan and eventualy one from B&B electronics(same company that makes atap). then i got a quatech pcmcia card and have had very few problems.
Old Aug 30, 2004 | 11:48 AM
TVWilkes's Avatar
I use a socket serial I/O pc card.This cost a little more money,but you will be happy.I could not get a usb to serial adapter to work at all.
Old Aug 31, 2004 | 12:02 PM
DAPSUPRSLO's Avatar
I have a mercury pcmcia card for $79.95 and haven't had a problem yet.
Old Aug 31, 2004 | 12:36 PM
romanss's Avatar
Good question Mikey
I have not had any success with my USB to serial adaptor.
But now I am going to look into the PCMCIA adaptor.
Thanks,
Roman
Old Aug 31, 2004 | 12:55 PM
Camaroholic's Avatar
Carputing does not recommend USB to Serial adapters. Only PCMCIA to Serial adapters.
FWIW, I could not get my Belkin unit to work with LS1Edit either. Works fine with LT1Edit & TTS Datamaster tho. But my laptop has a serial port on it - I was just playin' around.
Carputing is working on a new USB cable. It'll be a couple months before it's ready though. It's a total redesign.
Old Aug 31, 2004 | 02:20 PM
luv2spd's Avatar
I have a usb to serial adapter from sewell. It was only $18 and has worked flawlessly on both hptuners and when I had autotap. Highly recommended!
Old Aug 31, 2004 | 09:03 PM
romanss's Avatar
I can get autotap to work on my USB to serial adaptor but not LS1edit.
Roman
Old Sep 1, 2004 | 11:13 AM
TEA Brent's Avatar
I never got a usb to serial adaptor to work with edit on my laptop.
