Wideband install questions (preferably Zeitronix)
12 Second Truck Club
To anyone that has installed a Zeitronix WB, it might also apply to other WB setups, where do you get your RPM and TPS input from? For my window switch I tapped into a white wire off of the PCM, but had to set the switch up for a 4 cylinder for it to work right, not sure if that would work with the WB. Thanks, going to install this thing as soon as I hear something.
I just installed the Zeitronix software and it has a Cylinder setting. Did you put 8 in there or leave it at 4? That white #10 is what I tapped for my window switch and had to use 4 cylinders.
Originally Posted by HumpinSS
my WB unit has an rpm divisor and mine is set at either 2 or 4
