OBD II software
Old Sep 6, 2004 | 12:49 AM
robertbartsch's Avatar
Default OBD II software
I bought some OBD II software for $75 for my F-body LS1 about a year ago.
My 96 BMW, which also has the OBD 2 system, threw a code recently.
Can I use my F-body software for this analysis?
If no, were can I get this code read?
Thanks...
Old Sep 6, 2004 | 01:39 AM
hink9's Avatar
i tried reading a dtc from a 99 contour with my hptuner and i didnt work, maybe try the bmwdealer. the tech2 can do it also under general scan tool function,
Old Sep 6, 2004 | 06:38 AM
samz28's Avatar
autotap non-ls1 should pull it
Old Sep 6, 2004 | 06:50 AM
Were do you buy AutoTap?
I though AutoZone had a service to pull codes for a fee?
Old Sep 6, 2004 | 08:22 AM
samz28's Avatar
yes of course they will pull the codes but not erase them.
i think my bro found a harbor freight sale and got a hand held obd2 code reader for $19 dunno if they are on sale that much any more, but worth having.
Old Sep 6, 2004 | 05:06 PM
horist's Avatar
Sears has a cheapie one too... plug it in and it'll show the DTC
I know Ford, Chrystler and GM all use different protocols... dunno about BMW ...
Old Sep 7, 2004 | 02:26 AM
68LSS1's Avatar
This is the best one I found for a decent price. http://peakeresearch.com/
Old Sep 7, 2004 | 07:13 AM
I just bought the OBD11 software for the BMW (ISO). it was $122
Old Sep 8, 2004 | 02:37 AM
Apparently, there are 3 different OBD2 systems. The VPW system is used by GM; the ISO system is used by BMW.
I bought the ISO version of this software for $122.
www.obd-2.com
Old Sep 8, 2004 | 06:15 AM
samz28's Avatar
yeah, the iso version is usually a max-232 chip or an opto-isolator. I've built both, each consisted of bout $3 in parts plus an adapter to the plug if you aren't creative.
ISO = basically serial port but different voltages and baud rate.
VPW and the ford require a slightly more complex handshake.
for instance the ole audi a4 i had used iso but 10400 baud rate serial port. i dunno why the americans have to choose a more complex protocol, maybe its faster who knows. nowadays theres a single chip made (ASIC) that can do all 3 for like $15 in qty or so. But the board design is a bit more complex.
almost all cars from the EU use ISO since they almost all run bosch motronic ME, very sophisticated ecm, very common platform.
I guess thats kinda like how gm use(d) one similar ecm for most applications , no point in rewriting the o/s for each model car.
