What is your Commanded AFR at start-up?
Old Sep 6, 2004 | 10:46 AM
JNorris's Avatar
Moderator
Default What is your Commanded AFR at start-up?
On cold start up mine is between 4.5 and 7.5 which seems very rich to me. As soon as the engine fires and starts running the AFR goes to ~10.5:1.
On warm starts it is around 11:1 and goes to 12:1 after the engine starts to run and then on to 14.7:1.
Thanks
Old Sep 6, 2004 | 11:08 AM
MECHAM's Avatar
nothing wrong with that...
on cold start up the 02's are warming up and run rich.
Old Sep 6, 2004 | 09:44 PM
red ws6 99's Avatar
Sounds about right the o2 sensor are not used on startup (either cold or warm). On cold startup the o2 are not used until the closed loop enable temperature is met, around 142 deg F. On hot starts, its the temperature and I think some sort of time?
Gary
