random misfire, cant figure out whats wrong
The only thing ive done to the car lately is put headers on. Last night it started misfiring pretty bad on my way home for a few seconds and then it stopped. This morning i went to drive downtown and it did it again. I hooked it up to the scanner at the shop i work at and #6 was good sometimes and others it would miss about 70 or 80 times per 100 cycles. A couple other cylinders are missing every now and then but not really badly like this. I swapped the plug wire with one from another cylinder and the problem stayed with #6. I took out the plug and it looked fine but i put another one in just for the hell of it and it was fine for about 5 minutes. Then it started doing the same thing again. It was so bad sometimes that if i slowed down the car would stall. The only code im getting is for random misfire. The scanner says that there is no ignition coil fault either. I think im gonna need some help on this one. Thanks in advance.
