Speed Density and Timing
Old Sep 12, 2004 | 06:22 PM
nbmls1ta's Avatar
Default Speed Density and Timing
Well, I am in the middle of tuning my car in speed density. Unfortunately I was not able to use the timing histograms with the MAF unplugged, because the timing stayed in the .08 row. I asked here and no one could tell me a way around this. I e-mailed Keith at Hptuners and he responded withing a few minutes and told me the way around it. With the MAF unplugged you will have to remove the MAF PID from the scanner and then insert the Dynamic Airflow PID and then the timing histograms will work correctly!! Now I see no reason to hook up the MAF again. I hope this helps some of you and remeber, you have to remove the MAF pid or the scanner will use that for the timing, insert the Dynamic Airflow pid and it will work just like before. All thanks should go to Keith for this information. HP tuners is awesome and the customer service is second to none. Thanks again Keith.
Matt
Old Sep 12, 2004 | 06:50 PM
Another_User's Avatar
Matt
Aha. I meant to go looking for that useful tidbit of information. Thanks!
