"Real Time" LS1 tuning for the US Market.
Adkoonerstrator
Originally Posted by Delphi
We can easily incorporate "self-tune" as the PCM has its own WB A/R input socket which is processed by the PCM and is logged along with all the other Pids at 40 fps. WB A/F input to PCM is a 0 - 5 Volt signal so we can cater for many different brands of WB A/F Lamba meters.
This sounds very interesting if this product will only be slightly more than LS1edit.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks in advance
John
Originally Posted by XLR8NSS
The WB A/F input is something that you guys add to the stock PCM? What type of connector does it use?
This sounds very interesting if this product will only be slightly more than LS1edit.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Thanks in advance
John
Thanks in advance
John
The connector we are using on our protype is a "Mini UHF" socket. We have chosen this type of socket as it is usually used with shielded thin coax so as to keep any RF signal noise out. The Wide Band A/F signal going into the PCM is true raw data from the WB sensors own control box. We decided not to filter this signal with divide numbers so as not to influence the 40 fps log trace.
The result is a smooth air fuel ratio trace along with RPM MAP and what ever else you wish to log and view.
Adkoonerstrator
Sorry for delay. Things are very busy here at the moment.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
I have another question though.
If you sell this to individuals how will different makes/models/years be handled? Will the buyer have to send in their computer to be modified or will there be a core charge and you guys will put the appropriate year/model/make information in a new modified computer to send out?
Thanks again
John
No problem, I can imagine how busy. ![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Thanks again
John
Thanks again
John
As we progress we will endeavor to supply new modified PCM's when required.
Don't hesitate if you have any other questions.
LS1Tech Co-Founder
ADMIN here.
If you would like to advertise on the site, pm me for that info.
We have paying sponsors who already have similar products out or in r&d.
Please refrain from the solitication of biz unless you become a paid advertiser.
John
John
