PCM read time
Old Sep 20, 2004 | 12:53 AM
EightBall's Avatar
Default PCM read time
Im using LS1edit through a Keyspan usb->serial adapter and it is taking FOREVER to download the PCM flash file, on the order of 2 hours. Is anyone using the same setup or have any suggetions? I am really frustrated cuz I havent gotten a whole read in yet because it just takes too damn long
Thanks
-Mario
Old Sep 20, 2004 | 12:58 AM
horist's Avatar
damn.. edit does take forever to read.. but usually only took me about 20 minutes...
HPT takes about 2 minutes ...
If it's taking that long w/your edit... I'd think it's a problem w/ the keyspan (DO NOT try writing w/that if you ever do get a full read... ) unit....
I would do a few things
#1 uninstall and reinstall LS1 Edit
if it still fails to read
#2 borrow a friends laptop w/a REAL serial port...
if that works
#3 get a laptop w/a REAL serial port....
Old Sep 20, 2004 | 01:05 AM
Magnus's Avatar
LS1TECH Sponsor
A PCMCIA serial card may work better as well.
Old Sep 20, 2004 | 01:14 AM
EightBall's Avatar
are either of you running on USB adapters?
and hell no I wouldnt attempt a write until I got the read below 25 mins or so...
Was thinking of doing this
Old Sep 20, 2004 | 01:25 AM
2MuchRiceMakesMeSick's Avatar
I had that problem with windows xp. I put windows 2000 back on there and it read normal speed again. I do use hptuners.
Old Sep 20, 2004 | 01:26 AM
Magnus's Avatar
LS1TECH Sponsor
I do not use a USB adapter, but the product that I use does not have an issue with them.
I believe a PCMCIA card will work very well for you.
Old Sep 20, 2004 | 01:30 AM
EightBall's Avatar
If I were to put Win2000 on my current laptop I'd have to partition my HD...what a PITA that's gonna be...better than spending &60 on a PCMCIA card right away though...
