Timing Tuner Questions
1) is it supposed to not kick over with all the controls set to zero??
2) if i have the nitrous controls hooked up but i leave the N/A timing unchanged, will the motor run???? i don't want to unplug the tuner and just plug it back in when the nitrous relay is armed.
3) will the timing be retarded only when the power actually goes to open the solenoid or from the moment the power hits the relay (ie: when the system is armed with the switch.)
i FINALLY got around to finishing up the nitrous wiring today. I hooked the tuner up and set the RTD and window switch settings, but i left the N/A spark settings at 0.....the circuit works fine. when i arm the spray and hit the WOT switch i get the red LED to tell me the N2O secondary settings are working fine.
here's the problem. even with the nitrous settings set, if the spark base and spark WOT settings are on 0, the car will crank but won't start...
i use the jumper plug and bypass the tuner, and it starts right up. i then, re-connected the tuner and added one degree of base spark advance, and the car fired right up. why in the hell won't it kick over with the tuner plugged in if the spark base and WOT spark settings are on 0????
im sure i could probably have it run fine with an extra degree of N/A timing and just retard one more on the spray (just so it f**king starts with the tuner plugged in!), but that's not the point. PLEASE, can anyone shed some light on this???
make sure you have the microswitches pushed ALL THE WAY...i had the same problem when trying to set my upper RPM. the #4 switch looked like it was all the way up but i moved it with the tip of an awl and it went a little further.
