Car stumbled and guages zeroed when driving???
Old Sep 27, 2004 | 12:36 PM
99ZEOD's Avatar
Question *update*Car stumbled and guages zeroed when driving???
I was driving really easy a little while ago and the car started stumbling really bad. I check the guages and they all zeroed out, then immediately came back up. The car started to run fine again right after the guages registered again. Any ideas of what this could be?
***UPDATE***
Here's an update. I was wrong when I said all the guages zeroed. Yesterday and today it did it again and today it was really bad. But it was only the temp guage that went to zero not all like I said before. It stayed like this for about two miles. It would sputter, miss and idle at about 2k, then out of nowhere it straightened up. I messed around with the temp sending unit as it seemed like the culprit and it hasn't acted up again. Does anyone have any ideas besides the ones that are already posted?
Old Sep 27, 2004 | 12:55 PM
J&JsTA's Avatar
Almost sounds like a battery/ground problem ... check all your battery connections/cable and ground to ensure a nice clean connection without any corrosion
Old Sep 27, 2004 | 01:03 PM
mrr23's Avatar
did this happen during accleration? that happened to me twice at the track. battery holddown tray broke on the backside closest to headlight. when i launched, the battery rolled backwards, resulting in the positive cable hitting the AC accumulator bracket. thus shorting the electrical system. couldn't figure it out at first. kept hearing a thunking noise everytime i floored it. thought i broke the subframe and was pinching the wiring harness shorting out the guages. glad it wasn't that. check for a burn mark on the shiny canister thingy (accumulator) bracket just about 6" from the positive cable terminal on the battery.
Old Sep 27, 2004 | 01:08 PM
mikey's Avatar
LS1TECH Sponsor
This happened to a customer of mine. He found that the PCM connections were full of corosion. Pull the PCM connectors and check to see if there is a white powder in there. They are gold connections so there should not be a problem but just passing this possibility along. Once he cleaned the PCM connections, all was fine.
Old Sep 28, 2004 | 08:40 PM
99ZEOD's Avatar
TTT...please read update above.
Old Sep 29, 2004 | 05:27 AM
99ZEOD's Avatar
anybody?
Old Sep 29, 2004 | 06:09 AM
cablebandit's Avatar
the temp sending unit in the drivers side head can cause that symptom. Mine did it after I cracked mine doing a plug change. I think it was like 25 bux from a dealer
Old Sep 29, 2004 | 12:19 PM
DrkPhx's Avatar
Sorry to hijack, but the same exact thing happened to me at the track. It took me forever to find it but I did.
99ZEOD - when this happens does the trip odometer and clock radio reset? If so, it sounds like a short from the main or auxillary positive cable.
Old Sep 29, 2004 | 04:49 PM
99ZEOD's Avatar
BLKTA- The only guage affected was the temp.
I'm pretty sure it was just a bad connection with the temp sending unit. After I played around with it, it hasn't done it again.
