LM-1 O2 sensor lasting 2 months ! WTF???
Originally Posted by GM Muscle
Where did you get your sensor for $37? I'm scared that if I go to the VW dealer they will totaly gouge me.
Originally Posted by slow
well, that sucks
i was all about to buy a LM1 or 2.
Maybe the FJO dual setup is the way to go, hope its a little better durability, with the $165 each sensor.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I have one of these and it is AWESOME.. comes with logging software, etc. You can put a boost sensor (I have a boosted Z06), EGT, RPM, TPS... even has an output for the wideband sensor to convert it to a 0-1V signal to feed it to your stock computer to log with if you wanted to.
VERY NICE SETUP.. base is $299 and screen and all of the sensors I have about $600 in it including shipping.
Hope that helps.
Originally Posted by TT_Vert
any pics yet?
Thanks
dave
Thanks
dave
https://www.1stvwparts.com/part_number.html
Here is where I got the part# from: http://wbo2.com/lsu/default.htm
It is listed for $38.29 + shipping
I will get them pic's up in a few, forgot about it
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by GEN3Typhoon
www.zeitronix.com
Hope that helps.
Hope that helps.
any pics yet?
Thanks
dave
Thanks
dave
We were able to rescue them with WOT runs, and also by passing a propane torch (don't use anything else, like acetylene or MAP gas too hot) over the part that goes in the pipe. You can sometimes burn the carbon off enough to be able to use the sensor again.
