Compression ratio & cubic Inch Calculator
http://www.c5frc.com/calculators/Com...Calculator.htm
stock 99+ (5.7) chamber size is 66.7
deck heigh checks out anywhere from -.003 to .008
gasket thickness is .052 or .054 depending on graphite or MLS
it seems as if those above specs were put together to come up w/ the 10.1 CRr that that factory states even though alot of calculations come out to 10.22
