Car bucks at low RPMs
Thanks,
Mike
What does the VE table control? I'd look at Edit, but right now I'm caught up in the XP/SP2/AMD processor problem. So perhaps someone could explain how the ve table would help this problem.
Mike
The ve table is a large part of the airflow calculation at low rpm, low load because the MAF isn't very accurate down there. If you look at your ve table chances are it's not accurate with your cam, and it's also pretty rough, which in turn makes your fueling transition pretty sharply with rpm. By smoothing out the ve table your engine won't be as touchy for lack of a better word.
As for still being in closed loop even though you're in boost, PE is based on throttle position, not manifold pressure. At low rpms you don't go into PE (open loop) until around 60% throttle. You can change that in the PE threshold tables.
Mike
