Predator
Understand I am in Afganistan right now, so I dont have acess to my predator or car, but memory serving as it will...
You adjust the mph up, say 2mph for that shift if you want it to hold that gear longer, and then raise the rpm more than what it would see at that rpm, so if at shifts now at 32mph @ 5400rpms, you raise is like this: 34mph @ 5800rpms, keep in mind your rev limiter must be set higher too, of the RL is set to 5650 it will likely smack it on a shift. Shift time can get the shift itself quicker, but also reduces life of a stock trans too. Change fluid more often, I did mine every other month or about 2500 miles with oil. No problems until i forgot to change it a few times and added a 200shot on it.
If you have a logging tool you will see at what mph and rpm your actually shifting at, makes this process less of guess and more like reading science.
Good luck.
Charlie
