Help with LM-1 setup
Do I need to alter the Analog Output options on the LM-1 unit? If so, what do I change?
programmed into the LM-1 and the characteristic
that VCM_Scanner uses to interpret that voltage
are the same. Open up the LM-1 control program
and have a look at what it thinks it's putting out.
If I recall, Output 1 and Output 2 had two different
settings for output profile.
I have the AO1 set to 0-5V=10-20AFR, using AFR not lambda. The scanner is now reporting 19.8 and the handheld 20.8. When I blow on the sensor the handheld value drop a couple of full points, but the scanner value merely stays at ~19.8.
Ken says that's acceptable above. I stuck the sensor just inside the tailpipe and did some brief idle logging. Most of my cells were in the 13.x area at idle. But I seem to recall reading that anything post cat isn't accurate - but I don't know by how much or which way (lean/rich).
So most of my LTFT cells are showing red, and the idle AFR (at the tailpipe thru cats) is around 13.x.
