Newest Version of LS1edit..??????
Old Nov 11, 2004 | 11:42 AM
Z06PSI's Avatar
Default Newest Version of LS1edit..??????
What is the newest version...??? And can I download it anywhere..???? PM me if you want...
Old Nov 11, 2004 | 11:55 AM
HumpinSS's Avatar
Last i know was version 1.5
Old Nov 11, 2004 | 11:57 AM
AnthonyR's Avatar
1.5 is the latest upgrade. You can't download it, if you are out of upgrades from carputing you have to pay for it What version are you using now??
PM me you email address
Old Nov 11, 2004 | 12:00 PM
Z06PSI's Avatar
PM sent..........
Old Nov 11, 2004 | 12:06 PM
white2001formula's Avatar
1.5 is the newst version.
I have Version 1.21. Is this compatible with newer versions of LS1 Edit?
Example....I am reading my PCM, which was programmed by someone with a newer version of LS1 Edit. That same person is going to use the Edit file to make modifications. (They are recieving it via email because they are 300 miles away) Once they return it, I'll reprogram my car with the new Edit File.
1.21 Read--->1.5 Modify--->1.21 Re-Flash
Will this work?
Old Nov 11, 2004 | 01:47 PM
WicketMike's Avatar
it will work, you just wont have the tables to change that are in the new update
Old Nov 12, 2004 | 12:19 PM
rx7xj's Avatar
Sent you a pm as well
