Roughing in IFR for 60 lb Mototrons? (with fpr?)
I tried this in fueling for a couple of days and didn't get any responses, so I'm giving it a try over here.
Question 1:
Going from 28.8's (which are really 24's....) to the 60 lb'rs.
24 x 2.5 = 60 right?
So I would just multiply all my IFR entries by 2.5 to rough in the table?
Question 2:
I plan to hook up a vacuum line to my fpr to somewhat "boost reference" the fuel pressure. (I have the 97 vette rail on my ex-v6 fbody, with return line.)
I should flatten out the IFR table then? What is a good base table to start from? Or just start from the zero vacuum setting and push it all the way across?
(the car will be boosted soon)
Question 2a:
If the fpr sees vacuum and increase fuel pressure at idle, are the injectors going to be "too big" then to idle? From what I understand, they are barely in the minimum pulsewidth range (1.1 or so) as it is. I may have to abandon that idea.
Let me know if this should be in Forced Induction instead of Tuning.
Question 1:
Question 2:
Question 2a:
Ok, so 70/28.8 = 2.43
Q1:
2.43 times all entries in the IFR table?
Q2:
With vacuum to the fpr, what changes should I make to the IFR table?
Or are the 60's too big to be run with the fpr seeing vacuum?
(copying to the FI forum - finishing the rounds... No response in Fueling, minimal response in Tuning, maybe FI is the place to be.)
Q1:
Q2:
Are you expierencing an overly rich condition at idle with those injectors? I am just trying to find out if those injectors have a flaw. I am expierencing idle problems with the Motrons 60lbs.
high impedance injectors have a minimum open time -> and close time in high impedance.
so you'll get a crapload of gas at idle with such large flow. Hence why they came up with peak n hold low impedance injectors which can snap open much faster and the result is a much better idle.
You can get a conversion box somewhere, i'd guess the same injectors 60# (saturated) running in a true peak n hold 60# mode would idle WAY better and cruise at low loads way better.
I AM A MOTHERF*CKER
the IFR table is just a straight conversion from lb/hr to g/sec if the rating is the same. Might as well be exact since the conversion is pretty easy (I don't ever remember the lb - g conversion, but there are lb/hr to g/sec calculators all over the web, and included in HPT if that is your tuning software).
