Encrypted Files?
Basically when edit reads the PCM it encrypts the data as part of the process ... so only edit can open .ls1 files (I'm not aware of anyone having cracked the encryption yet... plus there would be legal issues then)
HPT Saves the files as native format and does not encrypt them
I just want to see what changes were made to my PCM so that I don't have to start programming from scratch, but I want to use HPtuners, so that I can split the cost with a friend. I hate sounding ingnorant, but I'm still trying to learn this stuff.
the encrypted files are only encrypted on your PC ... in the actual PCM they're not encrypted and HPT can read the tables fine
Basically Carputing chose to encrypt the file on your computer (Not sure at what point this encryption occurs) to prevent reverse engineering .. but there will be no problem reading your PCM, looking at the changes and then flashing your buddies PCM ...
data which is what you edit, and OS / program data which
you don't (though with the Pro version, you could, if you
knew what and how).
Any of the tuner tools can read the PCM straight-up.
Though there are some tuners out there who "lock" it
by messing with stuff so it's no longer "normal". Be
sure not to give these, any of your business unless
you like being "owned".
The data file that LS1-Edit works with, they encrypt
so only their tool can open it. If it's only 128K size
then perhaps it's only the data blocks and the OS
code is left out of it.
The data file HPTuners works with, is the straight
PCM binary image.
So if you have a LS1-Edit setup, you can't read the
.ls1 (?) file but you can read the PCM, and go from
there.
