Surging and bucking at low rpm and load.
Originally Posted by luv2spd
Another User - Did you say that turning off idle proportional fueling helped? I tried it a few weeks ago and it seemed to make my bucking a lot worse. Do you still have yours disabled?
Originally Posted by Cal
I just installed a new cam (TSP235/240) and now I'm getting some pretty severe bucking any time the rpm is below 2000 and at light load. I tried reducing spark timing everywhere below 2000 rpm and that helped a bunch with the bucking, but made the car fall on it's face trying to pull away from a stop. So I had to put about half the spark advance I took out back in.
I've noticed on EFILive that the spark advance bounces up and down a lot when the car is bucking, but I don't know if this is the cause or the effect. Lugging the engine a bit makes the spark advance back off and and bucking nearly stops.
Just looking for some new ideas; ArKay99 did you get this resolved?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
I have purchased the upgrade to EFILive and have been looking at some very interesting stuff on my buddies 2000 h/c FRC. We have made a map to get the averages of the IAC (Running Air Flow) table. We set the table up in 20C increments and MAF g/s and logged a bunch of closed throttle situations. We then plugged those averaged values into the RAF table and things got very smooth. No surging or bucking. I can't wait to do this on my car, but it probably will be a totally different beast by then.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by ArKay99
Not yet Cal. The car has been in hibernation since late December. Won't come out for 4 more weeks. Ground hog saw his shadow...
. Anyway, when I do bring it out I'm pulling the heads, redegreeing the cam, and putting on an LSX manifold with a NW 90mm tb.
I would be very interested to see how you did this, perhaps some screenshots, or a detailed explanation.
1: Select the Maps tab and find an open slot for a new map.
2: hit Ctrl+Enter to open up the 'Create new map' dialog.
3: In the Data tab select Desired IAC Air Flow (Grams/s)
4: In the Column tab in the Column: drop-down select Engine Coolant Temperature (*C)
a) Set the Columns: to 10
b) set the Col labels to: ,-40,-20,-,20,40,60,80,100,120,140
5: In the Row tab in the Row: drop-down select Air Flow Rate from Mass Air Flow Sensor (Grams/s)
a) Set the Rows: to 1
b) set the Row labels: to ?,400
6: Save as GM.IACDES_B Grams_s.map
Make sure those 3 pids are selected to scan with and start your car cold and start logging immediately. Let it warm to operating temp and log for a couple of minutes longer.
You can see the map filling with values as you go along. Then copy the Average values into the Idle/Idle Airflow table. These values will be the average desired running airflow values for that table. Then you can start fooling around with the Idle Airflow Parked table. (the above procedure was described by Nick Williams and Bink-being careful to give credit) This is a great starting point to get the idle transitions in line. What seems to be the underlying problem all on this thread are concerned with is the bucking and surging. These are byproducts of idle transition not performing well due to inaccurate RAF values. This causes theTB blade to servo open and closed to try to find where it should be and what it wants to be. If these values are off by only a tiny bit this servoing will continue. I can say this worked well on BLACKTOP2000's car. I haven't tried it on any others so I can't say this is a cure-all, but it makes sense to me. I wish I had more experience on this to relate though.
Arkay,
Here's the thread describing the procedure.
https://ls1tech.com/forums/pcm-diagnostics-tuning/267674-idle-transition-tuning.html
The solution to surging and cruising is often more simple than what I've been seeing done. Note in the writeup the importance of getting Idle Airflow Parked (IAC Park) correct. Often, changes in intake air temperature is the culprit. If you had Idle Aiflow Parked set perfectly (not likely) that would be actual airflow and is what is expected by the PCM. That is one cause of the TBlade hunting.
gojo and Nick are the brains behind the Idle tables and the 90 mm TB.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Originally Posted by Bink
Sorry, not me.
gojo and Nick are the brains behind the Idle tables and the 90 mm TB.![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
We all contribute Joel. These Forums are terrific.
#33
Originally Posted by P Mack
I thought we determined that the IAC wasn't causing the bucking problems. Another User said with the IAC locked it didn't make any difference. If that's the case, the RAF table would have no effect.
Many think that the MAF is the root of all evil...I think it is the RAF.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
#34
I understand your method and it looks pretty solid. I guess I will have to come up with a way to do this in excel with my HPTuners. You mentioned that after the RAF is dialed in that you will need to move onto the IAC park; has anyone come up with a how to for the park postion?
#35
Originally Posted by gojo
Arkay,
https://ls1tech.com/forums/showthread.php?t=267674
Sorry for putting you in the spotlight joel, I was winging it from work here and thought you were involved. BTW, you HAVE helped me quite a bit in the past so why not take a bow.
BTW, All this undocumented and misdocumentation reminds me of Windows programming...
#36
I'm going to try messing with my timing.
I've tried playing with the airflow seems to help but then i no longer needing my accel. pedal. car moves along on it's own.
I got about 32+ degrees of overlap and i'm surging at like 50
#37
As for the logging to Excel: With HPT and also before EFI had Maps you set up logging IACDES, IAT, ECT, MAF and/or Dynair if you need. Then just scroll though the results on the logger page and jot down the values to match. It's not a bad way to do it, since the averages are just that.
Arkay, Edit refused to correct having nothing indicated. EFI and HPT both have it right.
#38
Since we are all being humble, Nick is the brains and I am a sort of consultant, test mule.
I wasn't trying to be humble...I was stating the facts!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Figuring out the IAC and RAF tables was very significant
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I'm just trying to give credit where credit is due.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
![Icon Razz](https://ls1tech.com/forums/images/smilies2/icon_razz.gif)
