Would You...
Old Nov 26, 2004 | 06:23 PM
BoneSS's Avatar
Default Would You...
If you were going to buy HP Tuner, would you buy it with the extra hookup for wideband, or just the basic program/hardware? I don't know if it is worth the extra $150 for wideband support. I think someone in my area has a wideband I could use, but the local dyno has one also.
Old Nov 26, 2004 | 06:34 PM
foff667's Avatar
LS1TECH Sponsor
i upgraded...but mainly because ive started to tune other peoples cars so the need to have an incar wideband is important...for the avg person doing the tune once to their car on a dyno with a wideband might not need it...keep in mind most people recommend you remove the wideband after its intended use as they tend to die quickly from what i hear.
Old Nov 26, 2004 | 07:19 PM
monodax's Avatar
Well it does more than just handle the wideband input. I would definitely get the EIO upgrade. Just think you have 4 inputs and 2 outputs you can control by any parameter that it scans. So if you want to trigger a relay @ 100 TPS you can for nitrous. Or it saves you from buying a window switch as it can be wired to disable your Nitrous system if it is within a certain RPM range. Or you can make it illuminate shift lights or whatever you want. It really gives you so many options it would be hard for me to say not to order it. Just a shift light for our cars is pretty expensive and with this you can add one for a few dollars in parts @ radioshack.
Old Nov 26, 2004 | 08:00 PM
Another_User's Avatar
I am going to upgrade when I am ready to buy a wideband O2 system. I would wait. How far do you plan on going with upgrading the car?
Old Nov 26, 2004 | 10:23 PM
BoneSS's Avatar
Thanks guys for the input. I am either going to go with a bigger h/c package, or a turbo setup this summer...
Old Nov 27, 2004 | 09:22 AM
Bink's Avatar
I'd Definitely Go with the Wideband if I had your plans - if for nothing else...piece of mind.
Old Nov 27, 2004 | 09:43 AM
I agree with that, definitely get the wideband. Especially with a turbo package. You should upgrade everything else before the turbo. Try to find a good turbo cam.
Old Nov 27, 2004 | 10:13 AM
foff667's Avatar
LS1TECH Sponsor
yah with the upgrade you could keep an eye on egt & fuel pressure if need be.
Old Nov 27, 2004 | 10:36 PM
BoneSS's Avatar
I think I will get it. With it, do I next to order any extra piggybacks or what ever you call them?
Old Nov 27, 2004 | 10:46 PM
foff667's Avatar
LS1TECH Sponsor
if your only tuning your car and making it permenant you probably will only need the one included.
Old Nov 27, 2004 | 10:48 PM
BoneSS's Avatar
I would be using it on another friends car also, but mostly on mine.
Old Nov 28, 2004 | 09:36 PM
BoneSS's Avatar
ttt on the pigtail question, both with the wideband, and w/o getting the wideband.
