Looking for a "Cannon Plug" for firewall pass through connection
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I'm looking for a connector like a cannon plug that you’d see on an aircraft. I need to cut a hole in the firewall of my GT, and I'm looking to run the ECM into the cab of the car, but I need to connect it through the wall without having to push wires through the wall and what not like in the OEM design.
Where can I go to get this styled connector to which I can screw both sides of the connector through the firewall?
--Thanx
--Thanx
Try these guys. I used to be in the electronics field and they have almost anything you could want, cheap prices and same day shipment.
http://dkc3.digikey.com/PDF/T043/SectA.pdf
