Stumped on Warning Light
Old Dec 13, 2004 | 05:32 PM
Aegnor's Avatar
Question Stumped on Warning Light
Okay, short version:
What the heck could the "Service Vehicle" light mean?
Long version:
I go out to my car this morning, start it up, and the "Service Vehicle" light in the tach comes on. It doesn't go off during the drive to work (about 15-20 minutes in traffic). I looked it up in the Owner's Manual, and it just says it is a problem in the car that is not emmisions (read engine) related. But try as I might, I cannot think of anything else it could be . There are other warning lights for all the other stuff I can think of, i.e. ABS, AirBag, Low Oil, and even the "Check Gauges" light. When I start the car up in the afternoon to leave, the light comes on during startup and then turns off like all the other lights.
I'm going to go to the dealer tomorrow and have the codes read. The car's still in warranty, so hopefully whatever it is will be covered. The only possibility I can think of is that it may be like the Oil Change light that automatically comes on if not reset properly to remind you that you need an oil change. I say this because I am getting very close to 25K miles. I was at about 24,975 this morning, and now I'm at about 24,988. But I wasn't aware there was a service set for 25K, if that's what the light represents.
Any ideas will be appreciated. Thanks.
Old Dec 13, 2004 | 05:36 PM
horist's Avatar
I would put your stock airbox on (depending on issue they may try to use the K&N filter or the FIPK setup to cause problems) and bring it in for warranty
Could be alot of different things... but you need to have it scanned to know for sure... and if it's still in warranty you shouldn't have to worry about any outta pocket expenses
Old Dec 13, 2004 | 06:05 PM
Tiger2o69's Avatar
Mine come on today for the 1st time and it was because of a high idle which seems to be because i over ported my tb.
Thats not ur problem but just commenting.
Old Dec 13, 2004 | 06:40 PM
Uno99's Avatar
Mine came on today as well. Sorry no info on your situation. At least your still under Warr. Like Horist said you should put you r stock airlid back on before you go in to the dealership. IMO
Old Dec 13, 2004 | 09:58 PM
emarkay's Avatar
Service Vehicle is for a NON EMISSIONS related powertrain fault. PCM detects a fault that does not violate EPA regulations but may still cause a train of failures that may, so it's a "pre alert" to alert you to get it taken care of. You need a code reader to determine what the specific prob is.
Old Dec 14, 2004 | 07:36 AM
Uno99's Avatar
I heard auto zone can scan it for free or howmuch do they charge?
Old Dec 14, 2004 | 10:57 AM
Tiger2o69's Avatar
autozone is free
Old Dec 15, 2004 | 04:13 PM
Bill Bowling's Avatar
Talking
Have the code read by AutoZone or AdvanceAuto and then let us know what the code is.
Bill
