using hp tuners for a window switch
Old Dec 15, 2004 | 01:23 PM
Tiger2o69's Avatar
Default using hp tuners for a window switch
I read a while back this could be done w/ the new interface. i was just wondering if anyone is doing it and how it can be done.
Old Dec 15, 2004 | 01:33 PM
horist's Avatar
http://www.hptuners.com/products.html
Check out the user manual
Under Connecting to the Vehicle, Driving Relays
Unfortuanetly I'm not very good at reading wiring diagrams... Later I'll grab a relay and post up how I would do it... (I would wire the 2 12 volts , 1 switched 1 battery, then have the output pin of the Relay feeding the +12 volt for the device, and have HP Tuners control the ground... so the relay becomes ground activated.. HPT sends ground... relay then sends +12 to device)
Old Dec 15, 2004 | 03:38 PM
Tiger2o69's Avatar
Thanks maybe I can figure this out
