predator fan backwards???
Old Dec 24, 2004 | 12:04 AM
jimmyvette's Avatar
Default predator fan backwards???
...for a 2001 Corvette automatic...
I bought a predator and installed the performance tune over the stock tune and when I viewed the new settings I saw:
fan 1 - on 212
fan 1 - off 218.9
fan 2 - on 217.4
fan 2 - off 227
these off temps are higher than the on temps!!!
yet in the manual it says:
on temp MUST be higher than off temp.....
are these the proper performance settings for a stock 192 t-stat?
off temps should be lower, right....what am I missing?
Old Dec 24, 2004 | 08:26 AM
wait4me's Avatar
your correct, it looks like you may have a programmer that has been programmed incorrectly, thats not good, because it should make your car overheat if it ever got to 227, no more fans.....
Old Dec 24, 2004 | 06:41 PM
SmokingWS6's Avatar
Yep, definately reversed. Those temps are a tad high. I'd still lower them a tad depending on what thermostat you have.
