How does Wideband O2 hook up to HP Tuner?
Just curious how you'd go about hooking up a Wideband to the new HP Tuner. I have neither as of yet, but plan to order my HP Tuner sometime next month. Reason I ask, is that I will be adding my truck to my Tuner, but only running a Wideband in my Camaro. I assume the wideband is wired into the HP tuner as some point. I'm curious that when I want to remove the HP tuner to use in another vehicle, will I need to remove the wires and hide then away somewhere, or do they connect into an additional module which can simply be unplugged from the main unit?
