Dialing in MAF tables anyone????
My modified MAF table regression formula (from trendline):
y=3E-10x^3-8E-07x^2+0.0039x-2.9051
My stock MAF table regression formula (from trendline):
y=4E-10x^3-1E-06x^2+0.0058x-6.1464
Now to see if I can get that array formula working...
The raw values are:
I J L M N O Hz Maf g/sec 2687 8.08 0.00000000035453 -0.00000114936437 0.00577445218620 24.61452983
=L2*(I2^3)-M2*(I2^2)+0.0058*I2-6.1464
and the (rounded) raw formula is:
Maybe it's just late. To me the formula appears right, but the y value comes out to 24.x at 2687 RPM, whereas the stock g/sec is 8.x
But bear with me here, how does it compare to the data of the dynamic airflow? I'm under the thought that we are trying to create a MAF table that should line up closely to the dynamic airflow curve/function right? Is this wrong? The Best V8 Stories One Small Block at Time
THe difference between the the stock maf and the new maf table could be all the inaccuracies showing up from a lid, cam and other modifications that you a have made to the intake tract.
When you are finsihed plotting out your new MAF table and you flash the PCM the AFR's should stay the same....
I haven't tried any of this yet, just trying to lock down some concepts here but Mass AF is logged vs Frequencies right? and what is Dynamic Airflow logged against? RPMs? Ok so for example, let's say that at 2000 rpm raw MAF data reads 20 g/sec and the Dynamic airflow 15 g/sec, what would you do with this data, and how do we relate the data in terms in frequency? A newbie like me would just take the 15 g/sec and replace the 20 g/sec at whatever frequency it was set. This seems just way too easy so I'm pretty sure I'm wrong...
Average the dynamic airflow against the frequency (freq table is not dependant on rpm so we dont need it) so if you have an average of 20 for freqs 0-1500 hz i would put 20 g/sec in that colum
Not quite right if we are trying to correct maf airflow we need to log dynamic(ve derived) against raw frequency then average the data for those frequency ranges and plug them back inot the maf freq table
BTW, thanks to everyone for their input! This thread is becoming very very interesting and very very useful too! You guys rock!
Forget about mass airflow
. You love that pid, dont you? All you need is maf frequency and dynamic airflow....
