HP Tuners VCM Suite 3bar in action.
#41
Adkoonerstrator
Originally Posted by sscam68
right, and at the same time you're losing resolution. So can the stock piece still be used at that range, assuming you sent it off to get flow tested and mapped out, or do you have to get an aftermarket piece ala harlan?
#42
Granatelli
How is your MAF superior to the stock piece? What have your results shown? Do you offer accurate calibration curves to the end user if he/she has the capability of compensating with editing software?
I could be wrong here but the actual MAF itself is not the limiting factor, its the PCM....am I correct on this? Is this why you state you'll leave it up to the EFILives and HPTuners of the world?
Just a few Q's I had off the top of my head.
thanks
thanks
- an aftermarket MAF cannot make more power than a ported MAF of the exact same size, with computer tuning. an aftermarket MAF does not magically flow more air, nor does it magically make extra air and fuel appear in your engine.
- an aftermarket MAF cannot magically account for changes in your intake, such as a lid or aftermarket air intake, which means that it probably is not making your MAF readings any more accurate based on your induction type.
Aftermarket MAFs fill a niche in the aftermarket market for people that do not want to go to spend the money for and/or be bothered with computer tuning.
#44
Originally Posted by Another_User
If I may... It is not superior to a ported stock piece. There are a few simple facts:
At this point in the game an aftermarket MAF is a moot point, or is it? This is the reason for my questions and its rare an actual manufacturer gets on a forum to share info which is what I am trying to take advantage of
What baffles me, and what I am trying to understand, is why people change their MAF tables to compensate for fueling when it is nothing more than an input sensor like an IAT, O2, thermometer etc etc. Am I missing something here?
#45
Just to add a little more, I do agree with Granatelli in that a MAF is a great tool that can be used in engine management to compensate for many variables that are experienced in the real world that a strictly SD tune can't, but I also have limited experience with both.
So back to Granatelli's original question, how does the stock PCM compensate for a temp change once the SD is dialed in?
#46
7 Second Club
#47
7 Second Club
#49
Originally Posted by Nic00Z28M6
You change the MAF transfer function because air is not flowing across it like it was calibrated for when you use aftermarket lids and fittings. If you have your VE set correctly and you plug the MAF back in and it skews things you obviously have an improperly configured MAF transfer function... or a vacuum leak or other mechanical issue I suppose.
How so? The MAF doesn't need to be compensated, that I know of, after installing a lid, ported TB etc. Its just a measurement device. The reason for the foil, at least best I can figure, is to increase the velocity across the sensors for improved readings.
The only thing it can do is measure airflow irrespective of whats before or behind it.
#50
7 Second Club
#51
Only if the airflow was flat/laminar across the entire area it would work that way. The airflow through a mass air meter is never flat and will always be "spotty". Different airlids, etc will change that throwing the calibration off. This is basic stuff.
something else I am still overlooking?
#53
why do you want the maf? its just another intake restriction. Just hack the code to use speed density with fulltime wideband support, that is more logical. i'd bet if you exceed the maf range you would then default to SD mode anyways, its only logical.
#54
7 Second Club
Right, and the reason for the "honeycomb" in front of it, straighten flow out.....
#56
7 Second Club
#58
Yes, you are overlooking the simple fact that changing the intake in front of the MAF changes how air flows across the sensor honeycomb or not. Look at the differences between the calibrations for the Z06, trucks, etc. The MAF is the same, the transfer functions are different. Like I said before, this is pretty basic.
Different physical body, different flow characteristics, different calibrations.
The actual circuitry of the MAF is nothing more than a Wheatstone bridge, hence the resistor adjustment in the SLP MAF's to compensate for the missing airfoil.
The transfer function is, in part, locked into the actual physical characteristics of the MAF itself. Hence if you descreen or port the MAF you throw off the TF. There is a set physical airflow through that set physical orifice for a given set of conditions. You map out the output by using controled conditions i.e. a flow bench. Hell, don't take my word for it MM&FF did a write up on how a MAF is calibrated.
You keep bringing up changes in airflow, even with a completely stock car your going to get turbulent and laminer conditions under different driving conditions. How do you know you are not smoothing airflow out by adding a lid, or bellows? Does it change the TF, nope. Does it change airflow, yes.
yes it is simple.......but people don't understand or maybe there is something that I am missing but nobody has yet to post a legitimate reponse on how a Transfer function can change by changing a lid etc.
not trying to rib you the wrong way , its been a long time since I have looked at anything controls related, 3yrs to be exact, but the best that I can recall this is how a transducer works.
Frank
time to do some research......
#59
My .02 for what it's worth.
When you need a very wide range (0-800+whp) of 'perfect tune, street manors' SD is IMO the only way to go. What we need is idle nice, not stall on decel, cruise smooth at low throttle, and get good gas mileage. The problems I've had with MAF's is if they are large enough to read up to 800-1000whp they loose counts or generally have horrible idle/ stalling problems. And if you use a MAF small enough to maintain good idle and street manors, it max's out at XXX hp.
I have no problem SD tuning street cars that run 22psi everyday and 30+psi on weekends. They drive like stock, pass emissions, perfectly tuned at all times, get better mileage than stock. Adjustments for air temp are made by the IAT sensor, the map self adjusts for altitude. You can drive a well tuned SD car around the world with no problem. I have never heard of anyone wanting to change away from SD to go with a MAF. Only the OEM wants to use MAFs so the customer can modify or have a half broken car and it will self adjust by reading actual air mass entering the engine. One down side with SD is every time you change something on the car you have to retune.
Kevin
Kevin
#60
7 Second Club
Right, but the ZO6 MAF is a different diameter and I believe 02+'s come with no screen and an IAT sensor as a part of it compared to the truck MAFS. Different physical body, different flow characteristics, different calibrations.
