HP Tuners VCM Suite 3bar in action.
#81
Originally Posted by frcefed98
would the software you use happen to start with HP....want to share??....you guys get all the good info
Maybe but I can't divulge anything yet... but from what I've overheard on wire taps and from what I've seen... er um... I know nothingk! NOTHINGK!!!!!
#82
QUOTE:
As far as lids go, if I were going to use any MAF table with my lid (without building one from scratch), I would use a Holden table. I think that the way their intake was designed would more closely match our lids.
QUOTE:
I have a 98 LS1 with all the 'bolt-on' stuff. By 'trial & error' I came up with a 'nice' MAF table.
After switching over to HPTuner in November I came across the 'Holden' MAF table from a 'bin' file.
I couldn't believe how close my MAF 'table' was to the Holden one.
I now use the Holden MAF table as it was better at idle & off idle.
THE HOLDEN MAF TABLE IS JUST AWESOME FOR THE F-BODY WITH AN AFTERMARKET LID & BASIC 'BOLT-ONS'
DAVE
DAVE
#84
DAVE
DAVE
#85
Originally Posted by Another_User
Even now, after watching everyone spend their money, I have absolutely no idea why people run 90mm TBs with an 85mm MAF (unported). It baffles me.
#86
Originally Posted by sscam68
Granatelli
How is your MAF superior to the stock piece? What have your results shown? Do you offer accurate calibration curves to the end user if he/she has the capability of compensating with editing software?
I could be wrong here but the actual MAF itself is not the limiting factor, its the PCM....am I correct on this? Is this why you state you'll leave it up to the EFILives and HPTuners of the world?
Just a few Q's I had off the top of my head.
thanks
thanks
#87
Originally Posted by Nic00Z28M6
I have personally watched as a fast 90 setup was swapped to from an ls6/ported TB and they instantly picked up 25 rwhp, with an untouched 85mm maf in place. I would say it works just fine. Is it a max effort configuration, of course not. But that doesn't mean that it is a waste.
#88
If I may... It is not superior to a ported stock piece. There are a few simple facts:
- an aftermarket MAF cannot make more power than a ported MAF of the exact same size, with computer tuning. an aftermarket MAF does not magically flow more air, nor does it magically make extra air and fuel appear in your engine.
- an aftermarket MAF cannot magically account for changes in your intake, such as a lid or aftermarket air intake, which means that it probably is not making your MAF readings any more accurate based on your induction type.
Aftermarket MAFs fill a niche in the aftermarket market for people that do not want to go to spend the money for and/or be bothered with computer tuning.
#89
When you make a physical change to a MAF, ala porting, you are also changing its transfer function. The transfer function bascially is a mathmatical description of a phsyical property of a system. Crack open any controls engineering book and you'll see it's definition Before software was available the only way for compensating was an aftermarket MAF that had the compensation worked in in the form of resistors and would bring the readings back "in line". A point you touched on at the end.
At this point in the game an aftermarket MAF is a moot point, or is it? This is the reason for my questions and its rare an actual manufacturer gets on a forum to share info which is what I am trying to take advantage of
What baffles me, and what I am trying to understand, is why people change their MAF tables to compensate for fueling when it is nothing more than an input sensor like an IAT, O2, thermometer etc etc. Am I missing something here?
#90
At the end of page 5 you guys start talking about adding cold air lids and then talk how they change the way the meter works. a screened meter does not care what is in front of it . The screens do help laminar airflow. Then anothe guys talks about MMFF a ford magazine and how they explained the MAF in depth. A hitachi (or Ford style) meter has liitle to do with the Delphi meter and the way they operate. plus most of the mustangs out there done have a screenin the meter anyways. They are not on the same caliber as a Delphi design
#93
Well it must have to do with the runner and plenum differences rather than the TB diameter (which is what most people are thinking about with a 90mm setup). It just isn't physically possible that the TB size itself is making more power. Has anyone done a comparison between the Fast 78.. and the Fast 90mm? Are the manifolds the same, minus the TB inlet size?
:shrug: I still don't even know what a "transfer function" is.
I still argue that screened or not whatever is in front of the MAF will change it's relative output. A screen will smooth out the airflow, not redirect a "fast" spot of air from the corner to the resister. GM agrees with me. I also agree that the 04 holden MAF table tested perfect with me and an aftermarket airlid.
#94
I have calculated transfer functions before.
Question still remains. How does a lid change the transfer function. Post up the transfer function formulation and show where the airflow is the variable.
Shouldn't be hard since this is "basic stuff"
If I'm wrong, I am more than happy and willing to admit it. But nobody has been able to show otherwise.
#95
I don't think you guys understand what it truly is. And the MAF tables aren't it.
So how about this new 2/3 bar feature in HP Tuners? I know I am eagerly awaiting as I have customers that would take advantage of it.
#96
i still havent head if the SD tune compensates for weather, another_user says it uses the IAT to calulate, so IS THAT SUFFICANT FOR WEATHER CHANGES?
next will the SD tune allo desent fuel consuption for normal driving or will people get bad gas milage switching to a SD tune
those are the main conserns for me.
#97
My gas mileage picked up when i got rid of the the MAF.
This may be a trivial question but how does weather affect a sensor that measures airflow (mass airflow to be exact). The way I look at it, is the map sensor and the iat sensor can provide enough resloution of whats going on with the weather.
#98
I noticed no difference in gas mileage between a nicely dialed in SD tune and a nicely dialed in MAF tune.
#99
Yes it does compensate for weather, probably based on an internal calculation using the baro reading and the IAT sensor. I do see it drift from day to day but the closed loop fueling will always make idle/part throttle corrections just fine but WOT will always be off slightly. It is fine though, just not as accurate as a car that uses an actual sensor to measure the mass of air.
