Big Stuff 3 is installed
Old Jan 12, 2005 | 10:27 PM
2toneblown's Avatar
Default Big Stuff 3 is installed
Big Stuff 3 is the ****. Its the way to go. Install is 10 times easier than FAST thats for sure. It looks 10 times cleaner than the FAST. I am very happy and very impressed with this system. The only thing I did notice is that the software is kinda cheesy but im sure they will come out with newer versions fo the software. But I deffenetly recommend this over any of the other systems.
Old Jan 14, 2005 | 09:28 PM
foxspy's Avatar
That's badass!! I'm jealous. I want the BigStuff ecu. It will be on my next motor.
Old Jan 15, 2005 | 09:13 AM
NU BREED's Avatar
Default Big Stuff
Did All The Factory Sensors Plug Right In?did It Start Right Up?did You Have Any Problems If So What Kind.please Let Me Know,im Looking To Purchase One For My Lsx Turbo Motor..thanks..pete.
Old Jan 15, 2005 | 10:32 AM
Green Thunder's Avatar
Ordered mine on Friday, Hope to see it on Tuesday!! Did you piggy back your PCM and use it for trans controls or are you using the version with trans controls? Are you using stock gauges?
Old Jan 15, 2005 | 07:33 PM
2toneblown's Avatar
Everything plugged right in, I could not have asked for an easier install. I did not piggy back it, I am using it as a stand alone. I didnt get the trans control cause I am running a manual valve body TH400. No stock gauges.
Old Jan 15, 2005 | 08:15 PM
Is this in the truck in your sig?
Old Jan 16, 2005 | 08:36 PM
2toneblown's Avatar
Yes it is
Old Feb 6, 2005 | 12:27 AM
JVs95LS1Z28's Avatar
How Much Is It ?
Old Apr 22, 2005 | 10:02 PM
sb427f-car's Avatar
SSU'S Vice Mod
What updates have they made to the software interface? Does anyone have any screenshots??
Old Apr 22, 2005 | 10:15 PM
NA$TY-TA's Avatar
I have the software... i might be able to take a pic.
Flipper ,ight als i know he has it and has it working with stock gauges..... im going to do the same.
Kyle
Old Apr 22, 2005 | 10:30 PM
sb427f-car's Avatar
SSU'S Vice Mod
Yeah I caught those posts kyle. I'm just trying to figure out what I'll do when a "project" finally starts. HPT has some great points behind it, but I feel that the ability of BS3 to grow with you as you grow is also there. Plus, to have things like a progressive boost controler, 2step, and other odds, ends, and gadgetry that I can tap into and not have to buy the additional equipment and what not. The only real thing that concerns me is emmissions. But in MD we have the OBDII scan for I people 98 and +, so, turn off the right factory ECM stuff and I should be good to go, right?
By Brett Foote | 2026-06-04 05:00:17
