Help Please!!!!
Old Jan 30, 2005 | 07:51 PM
natronathon's Avatar
Default Help Please!!!!
After being pulled over today, my car threw a code when i started it back up. The code was po481 (i think the first two lettters were "po") Either way, i looked it up and it said there was a error with the cooling fan wires or relay. I checked out all the fuses, the relays with a voltmeter while tripping them, and I cant find any problem with anything. I even hard wired the relays and the fans worked at both speeds. Yet on the drive home, the light stayed on, but the car stayed under 185 degrees. Has this happened to anyone else? Does anyone know whats wrong with my car?
thanks for any info in advance!
nathan
Old Jan 31, 2005 | 01:08 AM
also i let it idle in my garage up till 210 degrees and the fans never turned on. Is this normal?
Old Feb 1, 2005 | 12:13 AM
for info purposes alone, i found out my problem. My pcm was no longer grounding the circuts that went to the fan relays. I will have to have my pcm replaced. Luckily GM guarantees the pcm up to 88000 mi, and I only have 55000. Ill let ya know if that fixes the problem.
Old Feb 1, 2005 | 03:22 AM
CRAGER's Avatar
Administrator
I think you'll have better luck finding help here in the PCM Diagnostics & Tuning Section.
Good luck and let us know what happens.
Peace,
Craig.
