tuning for fuel pump?
Old Jan 31, 2005 | 05:44 PM
WS6FirebirdTA00's Avatar
Default tuning for fuel pump?
what has to be done to compensate for larger fuel pump? what tables need to be adjusted for? the injector one? im gettin hp tuners soon so i would like to know some details on this. thanks guys
Old Jan 31, 2005 | 06:14 PM
foff667's Avatar
LS1TECH Sponsor
nothing.
Old Jan 31, 2005 | 07:22 PM
ok i was told that the bigger fuel pump would cause a need for retune. so its not true?
Old Jan 31, 2005 | 10:03 PM
foff667's Avatar
LS1TECH Sponsor
as far as i know it just makes sure your fp doesnt dip when you go wot because it has the ability to pump more fuel if needed...the injectors can only open so much for a given fuel pressure...if you bumped your fuel pressure or changed your injectors thats one thing.
Old Jan 31, 2005 | 10:09 PM
ok thanks
Old Feb 1, 2005 | 06:53 AM
wait4me's Avatar
yup, as long as the fuel pressure stays the same, you are ok. unless, your fuel pressure was dropping dramatically when they tuned it. Then you will run rich when you put in the new pump.
