AIR removal ? rear O2 removal ?
Edit -> Engine Diagnostics -> DTCs
any of the P01xx codes that mention AIR or rear O2s (bank x sensor 2) change error mode to No Error Reported
AIR system are P04xx codes I believe
Worst case if you miss any codes, scan the PCM , verify the code is rear O2 or AIR related and do the same for that code
