the ABS Inop/ Brake light
Old Feb 7, 2005 | 03:35 PM
chrismcdaniel's Avatar
Default the ABS Inop/ Brake light
i know its common when putting on welds, because of the different size front to back wheels. I did a search nd found several cases of this probelm. But never found a solution..
is there any adjustments that can be made through tunning to correct this problem?
thanks,
cmm
Old Feb 7, 2005 | 06:00 PM
ttt.... come one tunner guros..i know someone has an answer
Old Feb 15, 2005 | 04:40 PM
Gregg_98TA's Avatar
The ABS INOP and BRAKE lights are controled by the ABS unit. It is a masked ROM part and the programming can not be changed.
Old Feb 15, 2005 | 06:07 PM
thanks, i have been waiting for someone to post up for a while now.
Old Feb 15, 2005 | 06:26 PM
Tiger2o69's Avatar
I have problems stopping do you?
Old Feb 16, 2005 | 12:12 AM
bmfcamaro's Avatar
had that problem on my truck. hptuners will be working on the issue, probably not to soon though. what you can do is get someone with a tech 2 to change the ABS module for the correct tire size. that is what i did for my truck, 35" tires. not sure if it would work, but if your height has changed the abs module freaks out sometimes. hope this helps.
Old Feb 19, 2005 | 07:44 AM
Gregg_98TA's Avatar
The f-body ABS/TCS units from 98-02 are made by Bosch and it is not possible to change any of the programming. The only way that could be done is to have a developement ECU that can be reprogrammed. I work at Bosch in the s/w braking group and I can't even find an f-body developement ECU.
Best advice is to keep all wheels the same size and perferably within 3% of stock rolling diameter to retain good performance.
Old Feb 20, 2005 | 07:37 AM
RyanA's Avatar
Why not just add a DRAC between the back ABS sensor and the module and calibrate it yourself? Cheap, easy fix.
Ryan
Old Feb 20, 2005 | 10:05 AM
Ryan
yuor speaking greek to me man...i have no clue wha tyou are talking about..i was thinking about just puttingelectrical tape over those damn lights
Old Aug 28, 2005 | 04:18 PM
StangEaterSS's Avatar
"chrismcdaniel" did you ever find a fix for this? I just put my weld prostars on this week and am experiencing this problem. I am curious also to what i can do.
Old Aug 31, 2005 | 04:29 PM
Gregg_98TA's Avatar
You can't change the programming in the ABS unit as stated. If you were able to create a circuit to translate/ correct the signal before entering the ABS unit, you could fake it into believing everything was fine. Of course, you need to take into account the circuitry that detects opens and shorts in the wheel speed sensors. I also do not know how doing something like this would affect the braking performance.
