Need MAF help
Old Feb 7, 2005 | 11:38 PM
sdbrown84's Avatar
Default Need MAF help
I just purchased an older SLP MAF (the ones that say Delphi instead of SLP). I asked SLP if there was a difference and they only responded with there was an upgrade to the programming on the newer ones.
Do I have a problem putting this one on? I have an SLP air temp module as well, Will I cause any damage if I use that in conjunction with my current setup?
Thanks for the help.
Old Feb 8, 2005 | 12:14 AM
txhorns281's Avatar
the worse thing that will happen is that your fueling will be thrown completely off!!!!!!! lol... do you have any scanning/logging software?
Old Feb 8, 2005 | 04:29 PM
sdbrown84's Avatar
I dont unfortunatly. Is there some other way I can check it out, or should I simply not use one, or either of them?
Old Feb 8, 2005 | 08:38 PM
sdbrown84's Avatar
Has anyone had any trouble using these two pieces in conjunction with one another?
