tuning tips for TR224 cam
Old Feb 9, 2005 | 08:26 AM
oange ss's Avatar
Default tuning tips for TR224 cam
have HPTuners and have been reading alot the last couple days, I have the basics down and have a pretty good grasp on what to do, I just need to know how to do it :
1) what do I do to smooth out idle ?
2) how do I determine where LTFT need to adjusted, histogram ?
I will be gettin the wideband interface next week sometime. I wanna lean idle out to stoi and keep the AFR to about 12.8 at WOT, just need to know how to accomplish this. Any help would be greatly appreciated. thanx
Old Feb 9, 2005 | 03:48 PM
Cal's Avatar
Cal
To smooth out the idle, increase idle speed to 950 rpm and add 4 degrees of spark advance. You will be amazed at how well this cam will idle. Lean out the idle mixture by scaling back the VE 15%.
Old Feb 9, 2005 | 04:07 PM
oange ss's Avatar
4 degrees in what cells ?
I mult 400 rpm by .7 , 800 by .8 and 1200 by .9....havent loaded it yet but will this be a good setting ?.....by the way thanx for the input
Old Feb 9, 2005 | 06:40 PM
Michael Ozorowsky's Avatar
Go to my write-up:
http://www.hptuners.com/forum/YaBB.p...num=1101426165
Works like a CHARM
Old Feb 9, 2005 | 07:38 PM
oange ss's Avatar
do I adjust "Idle Air in Gear" even if I have an M6 ?
Old Feb 9, 2005 | 07:40 PM
oange ss's Avatar
"Go to Edit --> Engine --> IDLE -->IDLE AIRFLOW --> IAC Park Position Airflow vs. IAT: Raise all points from -40C and up to 21 "
you say raise to 21 but mine starts out at 35
Old Feb 10, 2005 | 11:29 AM
oange ss's Avatar
hello ?
Old Feb 10, 2005 | 12:19 PM
Blue Falcon's Avatar
I believe thats a typo it should be 40*C not -40*C
Old Feb 10, 2005 | 12:59 PM
oange ss's Avatar
that makes more sense
