Car is lean at idle and it will not richen up!
Thanks
try changing the maf where you idle, that should bring it back. "if not a leak"Can I take my intake off and put some kind of sealant on it, and then put it back in just to be safe?
My manifold air pressure is at 40 KP(spelling) at idle. Does that sound ok. That means no boost, right?
Thanks for the input guys!
More than likely it was the Granatelli.The stock unscreened meter will idle better because the air doesn't swirl around the meter.
Should I take off the intake and put sealant on it and reinstall it? Or is there a way to check the vacuum lines? My Autometer gauge reads about 15 to 17 vac at idle.
Thanks!
At this point, plug your MAF back in and map your LTFT's against the maf raw frequency. You can adjust your MAF table as necessary to get your LTFT back in line.
JMO
-Adam-
2. only THEN it makes sense to adjust ve
3. running lean at idle is fine, you're not putting any load on it anyway, so it's not gonna detonate, but you don't eat up gas without a reason either. if it idles fine, leave it lean.
Would someone please look at my files (test run 1 and test run 2) on the above site, and let me know what you think. I am lean at idle and rich elsewhere. This has caused me to fail smog.
Thanks
James
It looks like the calculated air is not correct. It isnt using the timing tables like it should. When you floor it and make boost it should be showing the cells being used lower on the timing tables, but you are in the middle no matter what????? So it is getting way more timing than it should. just a thought, jes
