Lm-1 To Hp Tuners?
Guys, I just purchased HP Tuners w/IO and pig tails. I did a search to find this answer and didn't find it. I'm sure I missed it but I did give it a shot. If this has already been covered, I'm sorry
Now I was looking at purchasing the LM1 from innovative and I know you have to have a "controller" to send the voltage scale to HP. Or at least I believe I read that correctly on the HP Tuners site. Does this mean when I order the lm1 that I need to get it with the Aux-Box for it to interface with HPT. Again, sorry if this has been answered and any help would be appreciated.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
nope, just need the LM-1 kit ... it can output via 2 analog outs that you program (comes w/serial cable and software) ... just configure it for 0 volt = 10AFR and 5v = 20AFR and you're set
[QUOTE=horist]nope, just need the LM-1 kit ... it can output via 2 analog outs that you program (comes w/serial cable and software) ... just configure it for 0 volt = 10AFR and 5v = 20AFR and you're set[/QUOTE
So, when you say it has analog outs does this mean the data is transferred through the supplied serial cable? Or do you use the serial cable to just program the LM1 unit. The reason I ask is that I thought it was suppose to interface with the IO that comes with hp tuner and not directly into the laptop. Not that this really has anything to do with what were talking about but I will be using a USB TO SERIAL adapter for the hp. Anyway, I'm sorry for sounding like an idiot, just not sure how this thing physically connects to hp. Thank you!
Serial cable plugs into LM1 for you to program it (has nothing to do w/logging but the LM-1 is customizable so you need to configure it)
Seperate cable provides analog output voltage per however you configure in software (easy to use software)
The instructions tell you which wire is which (it uses a stereo plug to plug into the LM1), you plug the analog out cable (included) into the LM-1, and attach the other end to your pig tails on the cable and you're done
