IFR table
Old Feb 12, 2005 | 05:48 PM
SnakeOiler's Avatar
Default IFR table
My question stems from the different programming that I see in STOCK pcm files concerning the values in the Injector Flow Rate table.
It seems the LS1 (F and Y body) cars have a curve map to them - every map cell has a different value, from low to high.
Truck files have a flat line constant - every map cell contains the same value.
Does anyone know why there is this difference? As in, why don't the trucks have the same flow curve?
Thanks
Old Feb 12, 2005 | 07:30 PM
John_D.'s Avatar
Do the trucks have a vacuum referenced fpr?
I'm going with a vacuum fpr setup made for a 97 vette, and will be flat lining my ifr table.
