i need 98 pcm pinouts for fuel pump relay control
im guessing somehow when i reinstlled my engine i pulled my fule pump relay wire loose in the bulk harness cuase i cant find any blown fusses, and the plug is not getting any power, so im thanking would i be able to splic into the fuel pump relay controle pinout on the pcm and wire directly back to the plug, i thank that pinout would be on the red connecter c1 pin 9 DK/GRN wire is this right? cuase i got that info from a 99 pcm pinout
Moderator
The link below and my service manual shows the fuel pump relay is in C2 (blue) connector, pin 37, dark green/white.
http://web.archive.org/web/200108080...pcmpin.html#c2
John
John
Perry
